Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys AQWA › Reply To: Ansys AQWA
Mike Pettit
Hi Karim,
Quick answer - no, the only way is to extract from Workbench.
More specifically, we do output the undamped natural modes of the freely-floating structure in still water, and you can find these at the bottom of the Hydrodynamic Diffraction LIS file (e.g. project_files\dp0\AQW\AQW\AQ\Analysis\ANALYSIS.LIS). These do not account for the mooring system, though.
The Natural Modes results you find in a Hydrodynamic Diffraction or Hydrodynamic Response Stability Analysis are running their own post-processing calculations to determine the natural modes of the system. Because the added mass and radiation damping are frequency-dependent, we need to scan through a whole range of frequencies to find the natural modes - this is what the 'mode match indicator' graph is showing. This scanning capability only exists in Aqwa Workbench.
I hope this helps!
Mike
