Ansys Learning Forum Forums Discuss Simulation General Mechanical Mapping stress isnt congruent Reply To: Mapping stress isnt congruent
Ashish Khemka
Hi Erik,
Do you want to do submodeling? I feel that is not is the case. Do you want to use the deformed geometry from 1st system and then apply thermal load on it? Even if you apply load from one analysis as initial condition then the body will try to regain its shape after initial loading.
Ashish Khemka
