Ansys Learning Forum Forums Discuss Simulation Photonics Source position in FDTD cannot be changed Reply To: Source position in FDTD cannot be changed
Guilin Sun
This is mostly due to another issue: are you sweep geometry or simulaiton span and monitor field result? if so, the matrix does not work. YOu will need to use fixed mesh size and mesh points during the sweep.
If this does not resolve the issue, please give the screenshots and the error message.
