Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Rotating bounding box for seed coordinates. › Reply To: Rotating bounding box for seed coordinates.
July 29, 2024 at 2:25 pm
Hi Sharath Sharathi,
Rocky doesn't support volumetric inlet rotation currently.
I'd suggest you to add a wall to close your geometries, so you can select every geometry as boundary for the volumetric inlet and fill exactly the area you want to. Then, use the Wall | Disable Time (set as small as possible) to remove the geometry interference from the simulation OR save the case for restart (check how to in Tutorial 14).
best regards,
Lucas
