Ansys Learning Forum Forums Discuss Simulation General Mechanical How to get the residual vectors under the multiple forces Reply To: How to get the residual vectors under the multiple forces
dlooman
It's not necessary to do restarts.  You can issue modcont,on and then do multiple solves in the modal.  Only the first solve will do the mode exctraction.  The remaining solves will create additional load vectors.
resvec,on
modcont,on
F,num_NODE_,F_DOF_INDEX_,1     !Generate the first load vector
solve    ! modal extraction and first load vector
F,num_NODE_,F_DOF_INDEX_,1   !Generate the second load vector
solve   ! create second load vector
F,num_Node...
solve
etc...
