Ansys Learning Forum Forums Discuss Simulation General Mechanical Fatigue Analysis and Test Validation Reply To: Fatigue Analysis and Test Validation
danielshaw
No.  Fatigue results are hard to "prove", because there is wide variation in the test results.  You will never be able to correleate a fatigue simulation result with single test result.  You need to have a statistically significant set of tests and confirm that the simulation result is within the range of test results.
