Ansys Learning Forum › Forums › Discuss Simulation › Fluids › System Coupling error › Reply To: System Coupling error
July 26, 2024 at 2:31 am
When system coupling run fails with error:
"*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 0.078 Â TIME= 13:31:29
 MAPDL is unable to connect to the system coupling service on XXXX through port #####.  Check the -schost and -scport options on the APDL command line in the System Coupling analysis and ensure that the host name and the port number are correct. "
 The workaround is to set this environment variable before starting System Coupling:
 ANSYS_RPC_LOCALACCESSONLY=1
