Innovation Space Logo
FREE STUDENT SOFTWARE Login
  • Community
  • Learning
  • Support
  • Educator
  • Career
  • Maker
  • AnsysGPT
  • Learning Forum
Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS-DYNA Error › Reply To: LS-DYNA Error
July 25, 2024 at 12:53 pm
Ashish Khemka
Please see if the following link helps: How to handle the following error: *** Error 70021 (OTH+21) Memory is set 3717636 words short memory size 70000000 Increase the memory size by one of the following where #### is the number of words requested: 1) On the command line set - memory=#### 2) In the input file define memory with *KEYWORD i.e., *KEYWORD #### or *KEYWORD memory=#### - Ansys Knowledge
Ashish Khemka
Connect with Ansys
  • Legal Notice
  • Privacy Notice
  • Cookie Policy
  • Export Compliance
  • Terms and Conditions
  • Report Piracy
  • Forum Rules & Guidelines
  • Site Map
© 2025 Copyright ANSYS, Inc
Please Login to Report Topic
Please Login to Share Feed
Ashish Khemka
Cancel Save Reply as Draft Publish
Edit Discussion
Avatar
Ashish Khemka
Add Tags
Cancel Save Draft Publish
You are navigating away from the AIS Discovery experience
Proceed
Continue
Ansys Assistant
Welcome to Ansys Assistant!
Login
Ansys Commercial Customers: Go to AnsysGPT
Your chat history is not stored
Hey there, you are quite inquisitive!
You have hit your hourly question limit.
Please retry after '10' minutes.
For questions, please reach out to ansyslearn@ansys.com.
RETRY
Are you sure you want to leave? The window will be closed.
OK
