Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys Forte 2023 R2 | Tutorial 5 | Intake Exhaust Valve Discharge Coefficient? › Reply To: Ansys Forte 2023 R2 | Tutorial 5 | Intake Exhaust Valve Discharge Coefficient?
July 25, 2024 at 10:22 am
Hi, Arturas,
You are doing the right thing. The results will be saved in a file called port_flow_monitor.csv in the run directory ("Nominal" by default) along with many other files generated by Forte. You can plot the results in Forte Monitor program or in Excel.
