Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Trouble with Axisymmetric Analysis › Reply To: Trouble with Axisymmetric Analysis
Sampat Kumar
You can also try Discovery, if you have the license, to check if this helps you import the 2D geometry in the Ansys mechanical or not. Discovery has some automate feature to remove the error. However, your geometry is simple so it will not affect your time to remove the errors in both CAD software. Changing CAD software from SC to Discovery might also help.
Best Regards,
Sampat
