Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An error occurred inside the SOLVER module: Enclosure type › Reply To: An error occurred inside the SOLVER module: Enclosure type
Sampat Kumar
Hi
if your model includes a shell body then apply the radiation boundary condition individually for the shell bodies. Try to run with the same enclosure number and the "close" enclosure type. I believe there's a possibility that some bodies are not covered by the radiation boundary condition enclosure, which explains why this error is occurring. Kindly verify this.
Secondly, I believe there is some leakage in the enclosure type, which is the reason you are receiving the error. if you are still unable to solve the problem even after adding all the bodies in the enclosure. The enclosure type assing "open" can be used to run it. When using the "open" enclosure type, there might be a possibility that some heat will seep into the surroundings, however, it will not affect your analysis.
Best Regards,
Sampat
