Ansys Learning Forum Forums Discuss Simulation Fluids Axial variation of bulk temperature in Fluent Reply To: Axial variation of bulk temperature in Fluent
It's the Surface Reports. If you choose mass weighted average for all the surfaces (iso-surface or plane) the report in the console will be per surface.
If you then want to calculate the HTC in Fluent there are Expressions that should do the same as CFX. Alternatively take the data from the console to Excel or similar. If you use an isosurface at the various positions you can also create that surface a second time & pick the wall when doing so to create a surface (line) to get the wall temperature (note, there are a few temperature options so check which one you want).Â
