Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Trouble with Axisymmetric Analysis › Reply To: Trouble with Axisymmetric Analysis
erik.kostson
Hi Chris
As this sounds urgent and as it would need looking at the geometry most likely (we should not pass data here - also we (Ansys empl.) can not download files here), I suggest that you open a support request up via your Channel Partner or if you are directly supported via the Ansys support portal.
Thank you and best wishes.
Erik Kostson
