Ansys Learning Forum › Forums › Discuss Simulation › Photonics › define a magneto-optic material using spatial varient refractive index › Reply To: define a magneto-optic material using spatial varient refractive index
July 22, 2024 at 7:04 pm
The importnk its self defines the geometry and material at the same time. Thus for a cylinderical object you can set its refractive index inside the cylinder and outside you can either set to be backgrould material or other material, depending on the device configuration.
If the geometry is different you will need to define each of them.
