Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › data doesn’t match in workbench transient thermal solution › Reply To: data doesn’t match in workbench transient thermal solution
July 22, 2024 at 1:20 pm
You're right. After checking, it turns out that the high temperature at the top keeps transferring to the lower temperature area at the bottom even after the heat flux stops, which is why the sound continues.
Thanks a lot. I guess I asked a silly question.
