Ansys Learning Forum › Forums › Discuss Simulation › Fluids › change position hinged connector › Reply To: change position hinged connector
July 19, 2024 at 12:40 pm
For a hinge joint the default stiffness is zero around the free rotational freedom (local joint X axis). There is no formula for defining the stiffness or damping, but the Aqwa Theory Manual explains how the values are used, and also how the friction coefficients are defined: 8.1.2. Effect of Articulation Stiffness, Damping and Friction (ansys.com).
Mike
