Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Running Ansys Fluent from commands › Reply To: Running Ansys Fluent from commands
July 19, 2024 at 10:07 am
In Fluent once is set up use the GUI File>Export>Case (and data if you can initialise the model). That's the one you need for running in standalone mode.Â
When running Fluent in standalone it will usually save to the working directory. However, if you've managed (or WB has!) to save a full path to the system it'll go somewhere random. So, it may be worth going through the file save, and any monitors to check the output isn't set to C:user/whatever/stuff/something.... Â
