Ansys Learning Forum Forums Installation and Licensing Ansys Products Running Ansys Fluent from commands Reply To: Running Ansys Fluent from commands
blanca.cerda
Which files? because I still have troubles of saving the simulation.
And i have questions about commands above that hasn.t been aswered:
”A few questions,
Which file i supposed to open with the comand “/file/rcd myfile”, It suggest the *.cas.h5 file, the only one I get without running the solution in workbech its the file: “FFF.1-Setup-Output.cas.h5” but after running and loading the mesh and boundary conditions, i got an error message saying that the same file wasn’t found.
Then, for solving, in the “Run Calculation” I use Number of time step, size of time step, and max number of iterations per time step. What command do u suggest to use to run the calculation and to save the file?”
And one more question, how do I preset where I want the files to be saved? Maybe that's why I cannot find them.
Thanks in advance,
Blanca
