Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Extraction of phase changes due to nanostructure › Reply To: Extraction of phase changes due to nanostructure
Greg Baethge
Hi, thank you for posting your question. The answer is not that trivial, there's no direct way to get this information from a monitor. We typically get the amplitude/phase information by calculating the S parameters of the structure. The principle is described in Metamaterial S parameter extraction. We use a dedicated analysis group from the object library for this:
The phase is obtained from angle(S), and the amplitude from abs(S)^2.
