Ansys Learning Forum Forums Discuss Simulation Photonics Inverse design Reply To: Inverse design
Greg Baethge
Hi Fetemeh,
Thank you for posting your question. eps_out can be simply set as 1 in the script. It should match the material properties outside of the structure, within the same thickness as the optimized objects.
