Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Material properties get lost while importing .cdb file › Reply To: Material properties get lost while importing .cdb file
mrife
Hi Bjarne
What material models are you using?  The External Model component in Workbench does not support every material model that MAPDL can define.  Check the Workbench help on the External Model system for more information (if you have access).
Do you link the External Data to the Engineering Data of the Analysis System too?
Mike
