Ansys Learning Forum Forums Discuss Simulation Photonics Insert a curved rectangular beam (structure) Reply To: Insert a curved rectangular beam (structure)
Amrita Pati
If you can define the curvature directly by it's coordinates on a plane, or have an equation that can be used to generate the co-ordinates, then the simplest apporach would be to use a polygon object.
