Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Static Analysis Solving for Long time › Reply To: Static Analysis Solving for Long time
July 10, 2024 at 3:54 pm
Ratio seems to be very high.Â
Are you running a linear analysis or a nonlinear analysis with Large Deflection turned on?
If it is a nonlinear analysis, can you trun off Large Deflection to test the model to see if it runs?
Also, if the model size is not very large and you have a sufficient memory in your computer, can you change the Solver Type to Direct (see attached picture below) to see if the model runs?
