Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Expansion joint to Spring › Reply To: Expansion joint to Spring
July 10, 2024 at 7:08 am
Ashish Khemka
How much time are these bodies increasing? Are you modeling them as solid bodies? What if you use shell elements to represent these bodies? Using shell elements seems a good approach.
If you want a replacement then bushing joints can be a choice but again you will need to find the stiffness in each direction for translation and rotation.
Ashish Khemka
