Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › SHELL 28 › Reply To: SHELL 28
July 9, 2024 at 2:20 pm
Hi Vladyslav
Shell28 element type was undocumented at version 17. The recomended replacement is to use Shell181 (the default linear shell) with orthotropic material properties and to change its keyopt 1 to be 1 to set the stiffness behavior to be membrane. If you are using a fairly new version of WB Mechanical these are UI options and you should not need a commands object at all.
Mike
