Ansys Learning Forum Forums Discuss Simulation Fluids System Coupling error Reply To: System Coupling error
Rahul
Please check the participant (fluent and mechanical) log files to know the cause of the failure?
If you are working in Workbench, find them at:
Fluent transcript: progress_files > DP0 > FFF > Fluent > solution.trn
Mechanical output file: DP0 > SYS > MECH > solution.out
SyC log file: DP0 > SC > SC > SyC > scLog.scl
If working with standalone System Coupling. Find them at:
Fluent transcript: Fluent_1 > solution.trn
Mechanical output file: Mechanical_2 > solution.out
SyC log file: SyC > scLog.scl
Ensure that individual participants (fluent and mechanical alone) works well before coupling with representative load on coupling interfaces. Review the BC’s in fluent and run it in Fluent only mode first.Â
