Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Variables of liquid viscosity, dissipation rate etc. in Fluent Expression › Reply To: Variables of liquid viscosity, dissipation rate etc. in Fluent Expression
You want to set the fluid properties, or something at the mixture level? Bear in mind the turbulent properties may be stored at phase or mixture level depending on the model and options chosen.
