Ansys Learning Forum › Forums › Discuss Simulation › Fluids › System Coupling error › Reply To: System Coupling error
July 4, 2024 at 1:37 am
Eun Jung Chae
It is a propeller simulation, and its setup is as follows.
In the structural model,
- material was chosen as aluminum alloy from “General Materials” in Engineering Data
- fluid-solid interface on blade faces that have data transfer
- fixed support at the root
In the system coupling component,
- created data transfer for the overlapped blade faces
- added output frequency as “All Steps”
- then simulated by “update” the solution
