Ansys Learning Forum Forums Discuss Simulation Preprocessing Generate locally fine mesh Reply To: Generate locally fine mesh
YH
Hi Keyur
Thank you for telling me. Shared topology works well.
I have one question. I used Design Modeler's ShareTopo at first, however the mesh did not shared in two bodies. After I moved the geometry to SpaceClaim and applied Shared Topology, then the mesh was shared.
I think Design Modeler's ShareTopo works since the edge color is pink indicating shared like the picture. Can you identify the reason?
Best
YH
