Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Problem after switching to 2024P1 › Reply To: Problem after switching to 2024P1
June 5, 2024 at 5:04 pm
Everything is fine there sir.
I noticed this strange thing. If I manually remove the SPC card from the k-file and add an empty line after MOTION_SET then the calculation works.
But this is a fatigue analysis based on a calculation that has already been carried out. And if this is not an analysis for fatigue, then there will be no fastening and the part will fly away.
