Ansys Learning Forum Forums Discuss Simulation Electronics Error importing PCB file in Icepak Reply To: Error importing PCB file in Icepak
Rabindra Paul
Hi William,
Thanks for asking question in this forum. Can you check with a workshop IDF file. It could be related to IDF format. If workshop IDF works then you may compare the format of your IDF and workshop IDF. If you need workshop IDF file, please create a support request in Ansys Customer Portal.
Hope this helps.
Rabindra
