Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to create parabolic cone structure in charge lumerical. › Reply To: How to create parabolic cone structure in charge lumerical.
Amrita Pati
Hi Sumit,
The simplest approach would have been to use custom object, however it is not supported in CHARGE. So, I believe it is not something you can even copy and paste from FDTD. If you have access to any external CAD based tool (like Solidworks), I will recommend you to create the geometry there and export it as an stl file. Then this could be imported into CHARGE. I will let you know if I find a simpler alternative.
Amrita
