Tasos Zacharakis
Hello Muzamil,
After solving the analysis, you go the design tree -> click on Solution -> go to ribbon -> Home tab -> Worksheet -> click on Available Solution Quantities ->  find DENER -> right click -> Create User Defined Results.
Then go to the design tree and evaluate this user defined result.
As stated here : CONTA174 (ansys.com), this result is available only when one of the following material models is used: TB,CZM,,,,BILI or TB,CZM,,,,EXPO.
Let me know if this helps.
Thank you,
Tasos
