Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Error messages ‘The demanded solver was not found in the specified path’ › Reply To: Error messages ‘The demanded solver was not found in the specified path’
Ian Delgado
Good day or night to everyone,
I am currently suffering the same issue, if not it is extremely similar.
Symptoms:
Error in solution branch of ansys mechanical using LS-DYNA.
General solver module error + Solver not found
Extra data:
Seems like LS-Run is working fine but I have not tested it with an independent ".k" file as i do not posses the knowledge on how to create one.
Thank you all for the help,
Ian Delgado (Engineering Student)
