Ansys Learning Forum Forums Discuss Simulation LS Dyna Time varying coupling pressure for SALE FSI Reply To: Time varying coupling pressure for SALE FSI
Abhemanyu Palaniswamy Chandrasekaran
Hi Ian,
I want to simulate a floating object that oscillates freely in water. I want to use the z coordinate of the deepest point of the floating object to calculate the hydrostatic pressure acting at that point. Then this hydrostatic pressure will be used to define the maximum coupling pressure in the load curve.
With the default values of PFAC, I find some numerical oscillations in the solution of the rigid body kinematic quantities. I would like to try using a coupling pressure load curve to see if these oscillations can be minimized.
Thanks & Regards
Abhemanyu
