Ansys Learning Forum › Forums › Discuss Simulation › Optics › How to obtain the phase distribution of each diffraction order after diffraction › Reply To: How to obtain the phase distribution of each diffraction order after diffraction
May 29, 2024 at 3:28 am
z_leejun
Dear Amrita, thank you very much for you answer!
"Is it possible to obtain its electric field through a monitor, and then set the angle of the corresponding plane to obtain the corresponding phase distribution?"
 I means that in the monitor, when I visualize the 'E' filed, and set the angle option,whether the result is the phase distribution that I want.
qiuxiang
