Ansys Learning Forum Forums Discuss Simulation Fluids Multiphase model Reply To: Multiphase model
nilay.pedram
To address the floating point exception error, you might need to refine your mesh, adjust your time step size, or review your boundary conditions and solver settings. It's not guaranteed that simply increasing the input velocity will allow you to run the simulation successfully without error. Moreover, a higher velocity will affect the Reynolds number, which in turn can impact the turbulence and stability of the flow. This could potentially lead to more convergence difficulties.
Please refer to Fluent Users Guide for more information - Chapter 25: Modeling Multiphase Flows (ansys.com)
If you are not able to access the link, refer to this forum discussion: How to access the ANSYS Online Help
