Ansys Learning Forum Forums Discuss Simulation Photonics FDTD Model for Interconnect Element Reply To: FDTD Model for Interconnect Element
GWANG
Hi Sujal Gupta,
Yes if you have large enough ports then you don't need to change the port when sweep through the port waveguide width. Please note that the ports shouldn't be overlapped with each other, and please visualize the mode profile to make sure the port size is good for all the port waveguide width. Regarding the sweep question, option 2 is the one to use. The s-parameter sweep only sweeps through the ports to generate the full s-parameter. You can use it with a regular sweep (which sweeps through the waveguide width) to export the full s-sparameter.
