Ansys Learning Forum › Forums › Discuss Simulation › Photonics › FDTD Model for Interconnect Element › Reply To: FDTD Model for Interconnect Element
May 24, 2024 at 10:59 am
Thank you, G. Wang for reply.
There is no direct application as such.
I understant you point. Just want to ensure it again. As you mentioned I shall keep my port width large/wide that will capture the exited mode even when the width of waveguide is incresed.
One more things that yet to be clearify:
Since I want to cotrol/change the width of one of waveguide from Interconnect, not in FDTD. So, how I shall I export my FDTD s-parameter for interconect.
- Do I need to first sweep the width of that waveguide before extracting s-parameter so that FDTD model can acknowledge the width varriation command from received from Interconnect. If so, does the s-parameter sweep itself capture the width sweep and genetate all the s-parameter corresp[onding to variation of width.Â
- If not, then how the s-parameter shall be exported.
Thank you.
