Ansys Learning Forum › Forums › Discuss Simulation › Photonics › HEAT: Results after sweep have different sizes -> lock meshing? › Reply To: HEAT: Results after sweep have different sizes -> lock meshing?
leon.neymeyer
I have this structure in which there are heating electrodes (here in yellow). I have heated these heating electrodes and want to look at the heat distribution in the substrate. This works great, but now I want to sweep across the width of the heating electrodes and look at the heat distribution at different widths. If I change the length manually, this works, but if I use the sweep function, the results of each sweep are different in size and therefore apparently cannot be saved. To change the width, I sweep over the x-span. I also placed a temperature monitor on a waveguide (the yellow squares below) to look at the results there.
Best Regards,
Leon
