Ansys Learning Forum › Forums › Discuss Simulation › Photonics › FDTD Model for Interconnect Element › Reply To: FDTD Model for Interconnect Element
May 23, 2024 at 6:22 pm
GWANG
Hi Sujal Gupta,
Thank you for the post. Could you please let me know some details on your applications? For example I understand that you want to sweep through the port waveguide width, and is this for a single wavelength or for a sweep of wavelength as well? Overall I would recommend using the port object, but you don't need to add multiple versions of it for different structure. Instead, you may use a large enough port that when the port waveguide width changes the port can always capture the full mode.Â
