Ansys Learning Forum Forums Discuss Simulation Photonics HEAT: Results after sweep have different sizes -> lock meshing? Reply To: HEAT: Results after sweep have different sizes -> lock meshing?
leon.neymeyer
Hi, thanks for your quick reply. I get this message when I try to run the sweep. It cannot save the data because each result of my "sweeploop" has a different size. Can I set the size of the result in scripting?
