Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-uniform heat flux expression › Reply To: Non-uniform heat flux expression
May 23, 2024 at 10:40 am
SRP
Both are same. It can be understood as if you replace 'W'=J/s=N.m/s=kg.m.m/s^3
so W/m^2=kg.m.m/(m^2.s^3)=kg/s^3
Hope this helps you.
