Ansys Learning Forum Forums Discuss Simulation Photonics HEAT: Results after sweep have different sizes -> lock meshing? Reply To: HEAT: Results after sweep have different sizes -> lock meshing?
Niki Papachristou
Hi Leon,
Thank you for reaching out to us! May I ask whether you have data in your optimization and Sweeps tab? You should have a red rectangle next to the name of your sweep:
If not, can you right click on it and Run it?
Let me know if that worked.
Kind Regards,
Niki
