Ansys Learning Forum Forums Discuss Simulation Photonics parabolic structure Reply To: parabolic structure
Niki Papachristou
Hi Minusunny,
Thank you for reaching out to us! We have this object in our libery and there you can see the equation that is used to be built:
I believe that if you use the script commands, addcustom - Script command, you will be able to built this structure.
Kind Regards,
Niki
