Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Manual adapt in y deraction › Reply To: Manual adapt in y deraction
May 22, 2024 at 1:20 pm
Refinement splits the cells as you're seeing, and there isn't an option to just split in one direction other than anisotropic which is often used to split inflation meshes. That option has other limitations so may not behave as you'd like.
