Ansys Learning Forum Forums Discuss Simulation Electronics ECE link in Simplorer Reply To: ECE link in Simplorer
Peter
Hi Timos.
with the transient solver I'm only able to export from an "imported table", but not from the parametric solution.
My idea is to create an inductance map of the motor by a parametric sweep of currents and rotor angular position using magnetostatic simulations. In this way, first I export the map as a table in .sml format, then I'll import the .sml table in Simplorer as follows:
in this way i should be able to create a ROM of the fem model. What it's still not clear to me is how to interect with the block Simplorer creates after importing the table:
the block has as inputs the 3-ph currents and rotor position, as outputs the inductance values. I guess i would also need the linkage fluxes to get the final output current.
How does the block work? if i enter the block from the left with the 3 current inputs and the rotor position, does the block output the three inductance (perhaps after interpolation) ?
if yes, i would only need to divide the output flux by the output inductance to obtain the output current.
thanks!!
