Ansys Learning Forum Forums Discuss Simulation General Mechanical Ayuda con Error: “Unable to access the source: EngineeringData” Reply To: Ayuda con Error: “Unable to access the source: EngineeringData”
Tasos Katsoudas
Hola José,
You can try archiving and unarchiving the project file to check if this resolves the issue.
Additionally, in many cases, when a program (e.g., Mechanical) does not operate as expected, it's required to reset Ansys' program settings by clearing the AppData folder. To reset the settings, follow the steps below:
  1. Close Workbench and its applications.
  2. Type %appdata% in Windows Explorer's Address bar (path) to access AppData / Roaming.
  3. Open the Ansys folder.
  4. Find the folder vXXY, where XXY is the release you are using. For example, if it's 2023R1, then the folder name should be v231.
  5. Rename the folder as vXXY_old, or similar. This is used to store the old settings in case you need to refer to them in the future.
  6. Create an empty folder named vXXY.
  7. Open vXXY_old and copy the MigratePreferences.txt file. Paste it into the new vXXY folder.
  8. Delete all content in the MigratePreferences.txt of the vXXY folder and save.
  9. Open Workbench. Files will be added automatically to the new folder.
I hope one of these methods helps resolve the issue you are facing.
Best regards,
Tasos
