Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unrealistic result in Non-linear FEA › Reply To: Unrealistic result in Non-linear FEA
May 14, 2024 at 12:19 pm
When checked in true scale the distortions are so small that you can't see anything, because (as you said) the stress value is low. However, when running the linear analysis of this same problem we had very high stress values. Do you know why they might suddenly be so low?
