Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient Thermal Simulation with two Simultaneous heat source. › Reply To: Transient Thermal Simulation with two Simultaneous heat source.
Sampat Kumar
Hi
What does it mean it doesn’t start? Are you able to see only one moving heat source along the specified path? Are you getting any warnings or errors while running the simulation?
Can you check if the starting times of the second moving heat source is the same?
Best Regards,
Sampat
